Zanussi PCS 584EW con- dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi PCS 584EW con- dryer
  • #22029
    rocker
    Have above machine has electronic timer..customer tell me she sets prog turns on then the timer goes stright to cooling part of cycle last mins.
    could this be a heater problem !! worried about getting involved as unable to test pcb.
    any advice please..
    John.
    #193468
    Re: Zanussi PCS 584EW con- dryer
    rocker wrote:could this be a heater problem !! worried about getting involved as unable to test pcb.
    Sure it could be just that John, testing PCB’s as you know is not an option. But what we can do first is to simply eliminate the other known problems. 😉
    Worry not, I’m sure you can suss it! 😀
    By the way, the model number isn’t correct? (It doesn’t come up on TDS anyway 😕 )
    #193469
    rocker
    cheers martin, good to have your reasurance..
