Zanussi sc5412 oven not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi sc5412 oven not working
  • #82551
    gr1688
    Oven on FIL’s Zanussi SC5412 is not heating up, have tested both elements (there is one on the left and one on the right) and I am getting a reading of 50 off both elements on continuity test, advice I have found online points to this reading meaning the elements are fine? if so, is there something else I should be checking? i’ve only ever found it to be the element in any oven I have had with this problem, and the fault has always been obvious so never had to test. I do not see any blown parts on elements or any misshape at all,
    thanks for any advice
    #420212
    Re: Zanussi sc5412 oven not working
    50 ohms is about right for each oven element (actual read should be 48 ohm). So I’d be thinking a fault with the oven timer (set on auto perhaps?) or the selector switch/thermostat?
    #420213
    gr1688
    Cheers Martin, I’ll try those next, not easy to do, cooker is 20 miles away 😀 I took elements out to take them home and test as I was at inlaws last night when the spoke of the oven not working and they don’t have a multimeter, ah well, looks like they getting another visit tonight from their daughter and favourite SIL (aye right! 😀 )
