I have a Zanussi washer, it has a zem sole motor underneath, its recently started skipping the wash cycles, it takes water in then jumps to the last 5 minutes of the cycle… any ideas?
I’ve checked the tacho magnet, as suggested in another forum, and bearing in mind I dont know what I’m looking for, everything seems okay…
Have you checked for earth leakage?
If you do have, you will have to eliminate which component is casuing the problem.
You will need a suitable meter (Megger) thats is capable of checking this as a standard multimeter will not do.
Un plug appliance if you are to investigate yourself :plug:
