Zanussi SL2300 fridge freezer – freezer is cold, fridge not
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi SL2300 fridge freezer – freezer is cold, fridge not
  • #96954
    sharpener
    We have a Zanussi model SL2300/2P fridge freezer (label says type B1740 no. K770403 1721). For the last ten years we have only used it around Christmas for the extra food. This year the freezer is sufficiently cold but the fridge section is scarcely colder than the room it is in. The compressor runs more or less continuously.
    Is this likely to be a problem with the thermostat, or something more serious?
    TIA, Chris
    #465604
    cant find your model
    if the compressor never stop that would mean it is incapable of getting to temp either through a gas shortage or compressor wear
    if it was a stat problem it would switch off
    sharpener
    electrofix wrote:cant find your model
    No, the SL2300 doesn’t come up in any spares listing I have checked so far either, though you might think Zanussi would have better records. It was bought for a flat I sold in 1982 so doesn’t owe us a lot!
    If it’s low on gas or a worn compressor I guess it’s not worth repairing but I will be sorry to see it go.
    Thanks, Chris
    #465606
    well if it was a stat a universal stat would work but its the fact it does not switch off that means it cant be the stat
