Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi Slim Integrated Dishwasher – ZDV12002FA
- This topic has 13 replies, 2 voices, and was last updated 10 years, 5 months ago by
bu06nne.
November 10, 2015 at 9:31 am #86632
bu06nne
ParticipantHi all
I recently had a Zannusi integrated dishwasher ZDV12002FA installed. Today I noticed that a plastic “arm” has disconnected from a hole at the very top of the washing machine. See image here:http://imgur.com/VrIJfRx
I tried pushing the arm back in to the hole but it doesn’t want to stay put.
1) What is this hole at the top of the dishwasher used for?
2) Will water or steam escape upwards through this hole and directly to the underside of my worksurface? Or is there a cap screwed to the top? I have vague recollections of seeing a black plastic screw cap on the very top of the washing machine.
3) Is there a way to fix this without completely dismantling and removing the dishwasher out? It’s a very snug fit and will be rather hard to pull out.
Cheers
NickNovember 10, 2015 at 9:58 am #432418kwatt
KeymasterRe: Zanussi Slim Integrated Dishwasher – ZDV12002FA
Hi Nick,
About the only thing I can see at the top to fix the upper arm is this:
http://shop.ukwhitegoods.co.uk/11193070 … ay-arm-nut
I can’t really see anything else it could be and, the image isn’t all that clear.
November 10, 2015 at 10:57 am #432419bu06nne
ParticipantRe: Zanussi Slim Integrated Dishwasher – ZDV12002FA
Thanks for the response. That looks like the thing that was on the outside of the dishwasher on the very top.
Does it need to be fixed – the arm is pretty rigid and is close to the correct position. My only concern is that where the arm previous was is a hole… I don’t really want water or steam going through the hole and out of the top of the machine. Do you know if it’s sealed on the otherside?
Cheers
NickNovember 10, 2015 at 11:05 am #432420bu06nne
Also just to clarify, the “arm” doesn’t spin round or anything, it runs along the back of the dishwasher and then along the top to the centre.
November 10, 2015 at 12:13 pm #432421kwatt
I’d need the PNC to check it, there’s multiple variants of that model.
November 10, 2015 at 1:03 pm #432422bu06nne
Hi, excuse my ignorance but what is a PNC?
It’s this one: http://www.zanussi.co.uk/products/dishwashing/built-in/fully_integrated/zdv12002fa/ if that helps.
Cheers
November 10, 2015 at 1:13 pm #432423kwatt
Explained here:
https://ukwhitegoods.freshdesk.com/supp … pare-parts
Essentially like the VIN number on your car. Without it, you can get incorrect parts, even a different machine on occasion.
The only place you can get it is on the rating plate of the machine, trust not other sources as they will invariably be incorrect.
November 10, 2015 at 1:28 pm #432424bu06nne
Thanks – I’ll have a look at it when I get in this evening and report back.
November 10, 2015 at 6:50 pm #432425bu06nne
Here we go: 911 079 006 03
November 10, 2015 at 7:53 pm #432426kwatt
This shows you the upper spray arm and feed pipe.
November 10, 2015 at 8:35 pm #432427bu06nne
Thanks for investigating. So the bit that has fallen out the hole is the very top bit of part 145 that overhangs.
It’s still in the right position, just not sitting in the hole. Do you think it’s sealed from above or would this lead straight to the work surface? I have memories of seeing a plastic cap on the outside of the machine above where this hole was.
Cheers
November 11, 2015 at 12:06 am #432428kwatt
No idea if I’m honest as I’ve not seen one and, I can’t make it out from the photo.
November 11, 2015 at 9:43 am #432429bu06nne
Ok thanks all the same. Do you know if the top part of that part serves any purpose other then to secure it to the machine?
November 11, 2015 at 9:47 am #432430kwatt
It’s likely there for a smaller top spray arm on some variants but, that’s a best guess.
