I have a Zanussi TLE1116W (pnc 913202661 01) that is faulty. When customer selects a program, sometimes it will start and run but most of the time it skips it’s entire cycle and the illuminations go straight to ‘end’. At this point it beeps 10 times, pauses for a few secconds and continues to beep 10 times untill it’s switched off. I have checked the heater, motor, the carbon brushes, and water valves. I have also used a mega on the heater element and motor and all is fine. Pump (askol) is running fine and door switch seems to be working perfect because if I try to run the machine with the door open, it beeps 4 times. It would seem the 10 beeps are an error code perhaps?
Anyone any ideas?
Thanks Regards,
Robert.
