zanussi small condensor dryer model FD 10
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi small condensor dryer model FD 10
  • #28047
    funkyboogy
    ordered fan for it, going back on wed, looks like a bit of a job,
    any pointers as to the best way to change,
    its the fan that has a small pulley attached to it that runs a small drive belt..
    cheers ally…
    #216651
    Re: zanussi small condensor dryer model FD 10
    What’s an FD10 when it’s at home?
    Are you sure you have the correct number? What’s the PNC?
    #216652
    funkyboogy
    sorry martin dont have pnc to hand,
    this thing looks like a wall mounted boiler, this is the 2nd one ive seen,
    weird looking thing..very compact.. about 60cm tall, 40cm wide and 35cm depth.
    ally
    #216653
    TC180
    smeghead
    went to one of these B’stards last year for same fault-fan change is ok , from memory its top and right side panels off. common fault is leaking
    from front near filter. awkward if mounted on wall.
    #216655
    cab
    did one yesterday. take the tank out, remove back cover, take of fan drive belt, remove right side panel (as you look at the back) the motor is visible, get a towel on the floor and stand the drier on its top, there are only two screws that retain the motor mounting then you slide the mounting plate forward to release it, might need a screwdriver it prise it a bit, take off the wiring and the motor is out, there is a service manual on tds, can supply it if need be.
    cab
    #216656
    funkyboogy
    cheers for reply,
    the new fan has a split pin in, is this how old fan is attached to motor shaft..
    ally
    #216657
    cab
    the main fan is on a splined d shaft, it knocks on the little fan wheel is held on with a spring clip.
    #216658
    funkyboogy
    cheers…
    can you send service manual to admin@atsscotland.co.uk
    ally…
    #216659
    funkyboogy
    CHEERS FOR EMAIL…
