Zanussi start button
  • #34243
    pmb
    FLE 1216w tipped machine against wall fitted door gasket,
    Now wont start when i press start button, all the other buttons and lights are ok
    door locks,
    tightened connections between boards
    I have not had this fault before,
    Any ideas
    #241800
    Micky 32
    Re: Zannusi start button
    I would check all plugs, also check motor brushes and check the motor for condensation. Fault could be just a coincidence. Door locks can give problems. Make sure you didn’t dislodge plug on interlock when you had your hands in there.
    #241801
    pmb wrote:Any ideas
    My guess is that the door interlock plug isn’t located correctly and that only 3 of the 4 contacts is making? Give the 4 way plug a wiggle? 😉
    #241802
    pmb
    Re: Zanussi start button
    Changed door lock, still the same.
    I most have causd it, but how ?
    #241803
    wilf
    check that the start button is actually working i.e. the board and button are makihg contact like the fault you sometimes get on the zanussi dryer where the diffiser breaks and the button fails to contact the switch
    wilf
    #241804
    pmb
    check the button by taking board off, it was ok
    #241805
    PGS
    Get your Megger out and do some fault finding. heater,Motor etc you will find something down to earth.
    #241806
    pmb
    Thanks for all the advice i will go back with the megger and give it a good check over
    Went back to machine and mysteriously now working fine thanks alot everyone for the advice we will see what happens 😀
