Zanussi stopped rinsing and spinning – HELP! Is it fiaxable?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi stopped rinsing and spinning – HELP! Is it fiaxable?
  • #26973
    eating42
    It’s a Quick ‘n Clean 1050 model (FLS 1185QW). Gets to rinse and spin, makes a bit of a noise and wont go on. I have to open the fluff filter to empty it by hand.
    Is it repairable? ❓
    #212106
    Re: Zanussi stopped rinsing and spinning – HELP! Is it fiaxa
    Pump blockages/failures are always repairable.
    eating42
    Re: Zanussi stopped rinsing and spinning – HELP! Is it fixa
    Thanks Penguin
    Any idea of cost implications?
    #212108
    To pull the pump and clear the blockage, most repairers will charge you for an hours work. Rates vary widely across the country, so you should discuss this when booking the appointment.
    If the pump has failed, you’ll need this little fellow as well:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=394
    Typically, you’d get some change from £80.
    Click the link below for a UKW repairer in your area.
