Zanussi t/d
  • #25782
    alfie
    I have a problem with the figure 8 fan belt. It keeps coming off ❗ Not sure of the model No. few months since my last visit but its similar to a TC 470 only a later model.
    There is no end float or play in either the fan or the motor shaft.
    I have already fitted two new ” green ” fan belts.
    Has this happened to any one else ?
    #207562
    Dales-Electronic
    Re: Zanussi t/d
    Not wishing to teach granny to suck eggs – are you sure you have the twist the correct way around. From experience, if you have it the wrong way around the belt comes off, if the correct way it doesn’t
    #207563
    cab
    Re: Zanussi t/d
    There is also a felt pad which helps stop the belt rubbing, but there is a kit to modify it from a belt driven to a electric driven fan.
    part no. 5024810008
    cab
    #207564
    alfie
    Re: Zanussi t/d
    Thanks for replies.
    Belt is definitely the right way round.
    How easy is it to wire this electric fan and what is the cost ?
    #207565
    alfie
    Re: Zanussi t/d
    Just a thought.
    Why was an electric driven fan offered as a replacement ?
    Was it because the belts kept coming off ?
    Or is it more efficient ?
    #207566
    DDSDDS
    Re: Zanussi t/d
    I Have had this fault many times the first few times the machine chucked the belt off within a few weeks,
    i noticed on one dryer the cabinet by the motor was bent so the motor was out of line straightened cabinet no more problems always check them now:)
