Zanussi T/D Model TC7102
  • #40968
    Alanj
    Hi Guys,
    above tumble dryer won’t start. On/off neon dimmly lit but goes bright when on/off switch pressed but no start. Switch is ok. If the cutouts on the heater on this dryer go o/c, does this stop it from starting completely.
    i.e. no motor action? 😕
    Alan
    #268214
    helo_75
    no, but the float switch stuck does 😉
    #268215
    Alanj
    Re: Zanussi T/D Model TC7102
    Thanks Helo_75, that’ll be a srtip down job then?
    Alan
    #268216
    bazza500
    The float switch is easily accessible from the lower rear panel where the motor pulley is.
    One screw and panel is off. no need for major strip down.
    #268217
    Alanj
    Hi Bazza,
    no small back panel on this one. Large banjo cover on back to get into heater, then whole back panel off. 🙁
    Alan
    #268218
    timdowning
    Have you checked the front switch which the condenser cover operates?
