Zanussi T/D not drying TC470
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi T/D not drying TC470
  • #17996
    Kirk
    Been out to this twice checked it out but could not find a fault have stripped it down looked for blockage but tank is filling fine changed stats, customer still says not drying what have I missed?
    Kirk
    #177325
    andy2
    Re: Zanussi T/D not drying TC470
    If the tank is filling then it is obviously taking some moisture out of the clothes.
    Have you checked that the fan belt has a twist in it as it will not dry properly if it has’nt. (fan goes in wrong direction).
    Andy 😀
    #177326
    aqualectric
    The little green fan belt on the back- is it worn and stretched? Was it off when you dismantled it? Change it in either case. Both cause a loss of volume of air over the heater; ie stats switch on / off regularly = very low heat in the drum. Also, make sure the belt is refitted in a ‘figure 8’ shape. (there’s a diagram of this on the back of the plastic cover plate). If it’s fitted in an ‘oval’ shape it will run the fan in reverse giving the same result as a slack belt – low air volume. Check the felt guide is in place under the green fan belt to stop the belt from fouling on itself where it crosses over ( figure 8 )
    Don’t forget the condenser – could be blocked as well. 😉
    Hope this helps!!!
    Steve.
    #177327
    Kirk
    Hi you two Guys… thanks for the info, will let you know how I get on…
    Kirk
    😀 8) 🙂 8)
    #177328
    Kentish
    What about a blocked door ducting?
    ie below the filter and out at the condenser coupling
    #177329
    Kirk
    Thanks for your input it made we look properly at the fan and found it was jamming up and running slow.
    Kirk
