zanussi t/d tc7102w Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi t/d tc7102w This topic has 5 replies, 3 voices, and was last updated 15 years, 5 months ago by adv. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts November 4, 2010 at 7:58 pm #58597 advParticipant dryer no heat whats most common reason on this model lads? November 4, 2010 at 8:15 pm #335032 geoff1Participant Re: zanussi t/d tc7102w Hi Its usually the thermostat inside the top of the door. Held on by 2 screws bit of a fiddle Part number 1258406014 Should read zero ohms if ok. If this has gone check filters, condensor unit and that there is no blockage to the water tank ( may complain of some water over floor) HTH Geoff November 4, 2010 at 8:55 pm #335033 advParticipant Re: zanussi t/d tc7102w ok thanks November 9, 2010 at 9:56 am #335034 advParticipant Re: zanussi t/d tc7102w hi ladss it easy to change this stat. whats the best way to tackle it does front facier an that have to come off cheers? November 9, 2010 at 10:06 am #335035 bazza500Participant Re: zanussi t/d tc7102w No, Stick your head inside the drum and undo the screw and it pulls inside. Remove wires, replace on new one and refit. 5 mins. November 9, 2010 at 10:32 am #335036 advParticipant Re: zanussi t/d tc7102w ok magic cheers Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
