Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi TC 481-W Condensing Tumble Dryer – Broken!
- This topic has 5 replies, 3 voices, and was last updated 21 years, 1 month ago by
admin.
March 2, 2005 at 9:29 am #8224
KeymasterHi can anyone help? My tumble dryer has been making some weird noises recently, and unless it is loaded very carefully, the drum won;t turn and there is a burning smell. Eek.
Now, however, it has stopped totally. There is no noise from the machine at all, ie. from the timer etc.
Any ideas? I assume its totally buggered, can I see a shopping trip coming on!March 2, 2005 at 9:54 am #127516Penguin45
ParticipantRe: Zanussi TC 481-W Condensing Tumble Dryer – Broken!
A common problem with these machine was the collapse of the rear drum bearing assembly, causing it to drop, in turn causing wierd noises and eventually the drum jamming or drive belt breaking.
Rear bearing 1250134-11/9, drum rear shaft 1230232-03/8. You will need to change both. Drop a line to spares@ukwhitegoods.com for price and availability.
Do nothing without pulling the plug first.
Penguin45.March 2, 2005 at 10:24 am #127517admin
KeymasterRe: Zanussi TC 481-W Condensing Tumble Dryer – Broken!
Thanks for your help. I’ll get hubby to remove the back of the machine and see if we can spot what is going on!
March 27, 2005 at 11:13 pm #127518admin
I have to replace the drive belt on mine, but from removing the top, it looks like the drum might fall out or need to be supported somehow.
If he’s done it, can you please tell me what is involved with removing the rear panel ?
Admin/Mods – Sirs or Ma’ams, any idea what the part number for the belt is ? 🙂
Thanks,
Jahn
March 28, 2005 at 12:10 am #127519Penguin45
Jahn,
Drive belt is p/no 12582888-10/7, contact spares@ukwhitegoods.com to order.I am unable to give exact instructions as to how to do the belt swap – sufficed to say it is a “screwdriver job” and that laying the dryer on its face helps.
Please check: http://www.ukwhitegoods.co.uk/modules.p … pic&t=4359 for an explanation.
Pull the plug first………
Penguin45.March 29, 2005 at 9:01 am #127520Jahn
Thank you Penguin45, may your God smile upon you always.
It looked like removing the back with all that multitude of screws might lead to the entire insides of the machine falling out.
I’ll go ahead with the attempted repair 😯
and post a follow-up if there’s anything relevant.😳 Umm, what plug do you mean …. BANG!! sizzle sizzle (JOKE)
I will definitely unplug everything in range.
Jahn
