Zanussi TC 7103W tumble dryer not working
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi TC 7103W tumble dryer not working
  • #44527
    andyhandy
    Good evening all,
    The above tumble dryer has stopped running. When you press the on off button the power neon glows. When you set the timer and press the start button nothing happens. The drum rotates by hand and the belt is intact. Any help would be appreciated.
    Many thanks
    andyhandy.
    #281310
    Re: Zanussi TC 7103W tumble dryer not working
    Door switch faulty or float switch in base jammed in “full” position would be the ones to start with.
    Power off before insertion of digits.
    helo_75
    BUT
    id check the switch behind the condenser door first
    #281312
    andyhandy
    Hi helo_75,
    You were right, the switch behind the front bottom righthand panel was faulty.
    Many thanks. Sorry for the delay coming back but I have been away.
