Zanussi TC481W Door open button broken – button appears jammed in – cant open door. How do i remove the front panel (1 philips screw rh side)(how does lh side fix) and / or how do i open the door. If the open door button should spring out then the ‘spring’ is not working
Is this an old machine?
Modern machines made by Zanussi including TC481 have a door mechanisn where you press door to close & press door again to release, they should also pull open if you use pressure.
