Zanussi TC7102w drive belt
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi TC7102w drive belt
  • #39921
    CHRIS24
    Does anyone know the correct way to fit a new belt on a Zanussi TC7102w condenser drier approx 2 years old.
    #264140
    Re: Zanussi TC7102w drive belt
    Remove side panels. release one end of front to rear top bars, pull drum back. Wrap belt round drum and secure top bars. Undo motor locks and fan covers, lift motor, feed belt round and refit. Refit tension spring to motor case and your mothers’ brother may indeed be called Robert.
    Power off first, please.
    CHRIS24
    Many thanks will give it a go over the weeknd.
    #264142
    CHRIS24
    job done , easy when you know how , slight problem getting belt over wheels at front other than that pretty straight forward.
    Once again many thanks
    #264143
    mikey4ward
    hello,
    Can you tell me if it is possible to tighten an existing belt on this model (Zanussi 7102w) I am getting symptoms that the belt is slipping. I have stripped it and just want to know if I need a new belt or if I can actually tighten the existing belt.
    Any help, greatly appreciated – many thanks.
    #264144
    mikey4ward wrote:I have stripped it and just want to know if I need a new belt or if I can actually tighten the existing belt.
    Then you would have noticed the belt is tensioned by a large spring against the motor tensioning the jockey pulley. If the rubber belt is shredded or perished it will need replacing. And often the black plastic jockey pulley wears and that too needs replacing. Considering the age of the appliance I would suggest you buy both!
