There is no power to heater, have checked float Switch ok, timer advances unable to test timer output to heater as there are a lot of cables fitted and dont have a wiring diagram. also not sure if there is a protection stat in line, cant see one.
Hi, I’ve been caught out with this one. There is a t/stat that goes and you gain access to it from inside the drum, open the door, and it’s screwed into the front panel above where the door closes.
Merv
