Zanussi TC7114W condenser dryer – noisy drum
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi TC7114W condenser dryer – noisy drum
  • #63140
    mjw1208
    Got a call to repair several of these tumble dryers for our local infantry officers mess (up several flights of stairs in various rooms) ,all appear to suffer with noisy drum or very stiff to turn drums . Before we go does anyone have any experience of these giving similair trouble and any advice would be most gratefully received thanks
    #352721
    Re: Zanussi TC7114W condenser dryer – noisy drum
    Rear bearing assy worn oval? Front drum felt come adrift? Jockey pulley doing a ‘wobbly’?
    #352722
    mjw1208
    First thought was a rear bearing though looked for a part thru qualtex and they don’t seem to list any rear bearings for this model so assumed fault maybe elsewhere ,but if anyone knows part numbers that would be great help so we can go armed with plenty of spares etc, thanks
    #352723
    Criscold
    It appears that this machine has roller supporting the front and would think these would be the most likely cause of the noise
    Part Numbers are
    Rear Bearing 1250134119
    Shaft/Axle 1250232053
    Front Roller 1254235003
    Roller Bush 1254250002
    Roller Screw 1240222123
    Good Luck
    Colin
    #352724
    mjw1208
    Thanks for part numbers and info much appreciated Mike
