Zanussi TC7114W drum not rotating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi TC7114W drum not rotating
  • #77719
    dja1
    The drum on our condenser dryer has stopped rotating. The hot air still blows. Is this the drive belt? Or something else? Is there an easy way to check?
    #403175
    Re: Zanussi TC7114W drum not rotating
    Belt broken. Lift the lid to see if it is still attached round the drum.
    #403176
    dja1
    Belt definitely broken. How easy is it to fix new one?
    #403177
    Fairly straightforward for anyone with good electro- mechanical knowledge to suss out.
    #403178
    dja1
    Can you give me instructions or point me to where I can find them?
    #403179
    dja1 wrote:Can you give me instructions or point me to where I can find them?
    Condensed version to get you started:
    Access the motor via right hand side panel removal, disconnect fan cowls and motor fixing mounts and tensioner spring, Remove drum rear bearing mounting……etc.
    The rest best left to your own initiative as it is pretty straightforward TBH. 😀
    #403180
    dja1
    Will it be straight forward for a complete novice??
    #403181
    dja1 wrote:Will it be straight forward for a complete novice??
    No not really, best you seek local help from an independent repairer. Find one in your area by clicking HERE
