zanussi TCE 7227 Fault…..
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum zanussi TCE 7227 Fault…..
  • #77911
    phil63
    Hi, i have a zanussi tumble dryer. It goes in the clockwise direction for about 3-4 mins, stops then tries to go in the opp direction, it starts to go then stops. Then the lights blink twice and beeps twice at the same time. I then have to turn switch to zero (off) and start the whole procedure again. Is there anyone who may have an idea as to the fault…. Ta
    #403820
    Re: zanussi TCE 7227 Fault…..
    Either the pump has failed or the main PCB is faulty. Check out the pump first.
    #403821
    phil63
    Thanks, Will try pump first…. Will let you know..Ta
    #403822
    phil63
    Fitted new pump, still doing same thing. Looks like it may need a new PCB. Anyone know where i can get one cheaply.. Thanks
    #403823
    Phil, I suggested you check the pump first. By that I meant check to see if it is functioning and not go to the expense of replacing it! Throwing parts at it is not the best or the cheapest solution. Forget sourcing a PCB and instead check out that the pump/float system functions and discharges water into the water container. Then report back please.
    #403824
    phil63
    Yes when i fitted the new pump, after a while it started working fine, dryer doing its thing, turning clockwise then anti-clockwise for a while. filling the water container, now stopped and not pumping at all.
    #403825
    Errrr? You are testing it with a load of damp clothing each time aren’t you?
    #403826
    phil63
    yes sir i am. the waterbowl where the pump is fills up but the pump does not activate, which is why i got the pump thinking it was that.
    #403827
    phil63
    How do i test the pump?
    #403828
    phil63 wrote:How do i test the pump?
    Phil, we have to assume those to whom we give advice have a degree of electrical knowledge. I’m not sure you have because of that question and therefore would advise you to contact a local repairer.
    #403829
    phil63
    Thank you for your help anyway. but the reason i asked that question was because when i powered it up, it didn’t operate, thats why i asked, just in case there was a specific way to do it.. there is power going in and coming out…
    Thanks…
