Zanussi TCE 7276 W no heat
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi TCE 7276 W no heat
  • #72049
    creature3
    Hi folks.
    I need help as I’m out of my depth and drowning here!….lol. I’ve changed the heater element and the temperature probe (really enjoyed taking it apart and putting it back together too!) but the damned thing still won’t heat. Everything seems to be working. Drum spins, air moves and it sounds good but…….no heat. When I contacted Zanussi parts they said that the only two things they could offer as replacement parts to rectify the problem were the heater and probe. Now £80 later I’m no further forward. I’ve obviously missed something. Any suggestions. There’s no trip on the back of the machine either.
    Help!!
    #383215
    captaincaveman1
    Re: Zanussi TCE 7276 W no heat
    If your sure that both parts were correct and wired correctly then it has to be the heater relay on the main circuit board itself at fault
    #383216
    this is a long shot but did you have wet clothes in when you tested it. dont know with this machine but some dryers dont start to heat till dampness is detected
    bryan-206
    Agreed with above. Most sensor dry driers will check dampness before heating. Heater relay on PCb is common failure for zanussi
    #383218
    mjg64
    I have the same situation with a Zanussi TCE 7276w. I have replaced the heating element and it still does not heat. Where do I locate the temperature probe and can I test this with a multimeter before getting a replacement? Thanks
    #383219
    Left hand side near capacitor and can be tested with meter.
    #383220
    mjg64
    Thanks. Getting a reading of about 4k ohms at room temp. I’m assuming this means it is bad. Can anybody confirm please.
    #383221
    It should be closer to 6k @ 20c.
