Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi TCE7227W TUMBLE DRYER
- This topic has 9 replies, 5 voices, and was last updated 16 years, 10 months ago by
garn.
May 22, 2009 at 9:43 am #45918
garn
ParticipantP NO 916096121 NEXUS
HI GARN HEAR
I HAVE A LONG RUN TO DAY TO GET TO THIS APPLIANCE THE CUSTOMER REPORTS THAT WHEN THE MACHINE IS SWITCH ON THE DRUM ONLY ROTATES FOUR CYCLES THEN STOPS
BY THE SOUND OF IT NO REVERCE ACTION ❓should i be looking in the direction of the Module PCB ❓
thanks garn.
May 22, 2009 at 10:19 am #287619Martin
ParticipantRe: zanussi TCE7227W TUMBLE DRYER
garn wrote:should i be looking in the direction of the Module PCB ❓
HI MARTIN HEAR. 😉
I would look at that lastly if I were you. Better to look first at the drum carbon brushes, that the pump isn’t blocked to the water tank. That the element and TOC’s are functioning and the stat in the front drum cowling is OK?
May 22, 2009 at 10:54 am #287620garn
OK martin thanks for the input
the diagnostics wear done over the phone its sometimes difficult to a say whats wrong without siteing the appliance
its approx two years old it may have never been cleaned
if I’m correct the appliance is designed on start of 4 rotations one way then back in reverse the other way for a few times to separate the clothes ❓ it sounds like its stopping on the reverse cycle .thanks mate..
May 23, 2009 at 10:35 am #287621garn
mmm. this ones its a bit of a bugger at the moment 😕
May 23, 2009 at 11:04 am #287622timdowning
Why? What did you find?
May 23, 2009 at 3:49 pm #287623garn
THE PROBLEM IS INTERMITANT
I WILL HAVE CHECK FULL FUNCTION WITH DIANOSTICS
SO FAR STARTS ROTATES STOPS AFTER FOUR REVALUTIONS
REVERSE ACTION SOMETIMES OR NOT AT ALL OR IT MOVES MM OR TWO
OR NO DRUM ACTION .
MOTOR COMPASITOR ❓
THERE IS A BULITON OUT ON THIS MODEL MOTOR COMPASITOR AT THE MOMENTTHANKS FOR THE RESPONCE
GARN 😉
PS AINT GOT MY MEGGAR AT THE MOMENT
HAD TO LAND IT ON SOMEONES HEAD £680
BELEAVE IT OR NOT COMEING OF A JOB GOT PULLED BY TO IMIGRINTS
THATS ANOTHER STORY FOR LATER WHICH IS TRUE ❗May 23, 2009 at 4:40 pm #287624Turbo
LOOKING FORWARD TO THAT STORY 😉
Graham
May 23, 2009 at 7:05 pm #287625Madmac
Ditto. 😉
May 24, 2009 at 8:33 am #287626Martin
garn wrote:THE PROBLEM IS INTERMITANT
OR NO DRUM ACTION .You are testing this machine with a load of damp washing I presume?
May 24, 2009 at 3:24 pm #287627garn
yep got some damp teatowels in it.
theres a service bulletin out on dryers 4546 exsept the env06 models
2uf capacitor 12oo81/3 is probmatic has to be updated to 125 64 18 20/1 with an internal heater.
its to stop the old capacitor remaining charged and being damagedgarn still 😕
ps i mite have to change this Repair Anything From A Wheelbarrow To A Four Engine Bomber! 😥
