Pnc:916092667-00
Customer reports that she had a similar fault fixed on this machine 5 or 6 years ago.
Select programme, display lights up and start button light flashes but when start button is pressed, nothing happens except for the light flashing.
Machine looks quite sound overall.
Removed facia and found the thin plastic ‘Diffuser luminous’ doofer broken above the start switch. Simples thought I, ordered part 1257429306 and returned today to fit but it is still the same.
The problem is that because this switch ‘appears’ to be malfunctioning you cannot then run the diagnostics. The tiny switch on the user interface PCB looks to be OK.
Anyone have any ideas/suggestions. I’m leaning towards the PCB being at fault myself.
TIA.
