Zanussi TD 524
  • #43011
    mike100
    Fitted new heater element as could only get half heat on orig.
    Got full heat on test after fitting but got called back by customer saying doing same as before.
    Half heat switch seems to be ok.
    Am I missing something here?
    Replies much appreciated
    Mike
    #275676
    Re: Zanussi TD 524
    hi
    was…. the stats on the old heater ify………test with meter….+other stat on dryer
    if thay are ok then may be burt out contact in timer 😮 …….not sending power down ……tap timer when on and see if she heats up…..
    canufixit
    #275677
    mike100
    Re: Zanussi TD 524
    Going back when they return from hols.
    Will try what you suggest.
    Mike
