Hi i am having problems with a Zanussi TCE7227w. When it is set on either a timed or sensor program the machine starts tumbling, heating and pumping whatever water is in the base, but after roughly 30 secs it stops. Then after a little while of doing nothing it beeps and shows the cycle finished light. I have tested it with wet washing in here, cleaned a partially blocked condenser, cleaned pump and float, replaced sensor arm and cleaned contact patch on drum with wire wool and replaced 6uf capacitor with 8uf to test it. There is a 2uf capacitor there as well can this cause these problems? Any help would be great guys :lesson:
Thanks Peter
