Guys,
Popped into a job on Friday where the customer had a Zanussi TD4112W tumble drier that was on the blink. Customer reports putting the machine on and it blowing a fuse after about 5 minutes of use.
Flying through I tried the machine and it operated on full heat for about 5 minutes before turning itself off. At first I thought a fuse had blown but this was not the case. What I did notice was that when the door was opened the on/off led lit up and the timer continued to operate. Upon closing the door to the drier the led went out and the timer stopped. It took about 5 minutes for the machine to kick back in and after a few more minutes of operating the machine did the same again. I’ve checked the heater element/thermostats and all seemed to be fine. Am I missing another thermostat elsewhere, or is the problem elsewhere?
Any help would be appreciated.
Mark
