Hi, i have a zanussi TD4112w that appears to be working perfectly normal except that it does not generate any heat – do i assume it to be the heating element that needs replacing or could it be anything else – like a faulty cool switch or thermostat
Thanks in advance
Re: Zanussi TD4112W No heat but everything else ok
You’ll need a test meter and the basic skill to perform resistance testing through the various components and circuits. The thermostats should read 0 ohms as they should all be normally closed. The heater should show 25-30 ohms, typically.
