Zanussi TD4212W – Heater & thermostat changed but still blowing cold – what next?
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Zanussi TD4212W – Heater & thermostat changed but still blowing cold – what next?
  • #99128
    Grinner
    So, I have a Zanussi TD4212W. Recently it started blowing cold air only. I have changed the heater and the front-door thermostat after reading advice from many threads on here. But it is still blowing cold air 🙁
    What else could it be and how can I check before throwing even more money on spare parts? Thanks in advance
    #475131
    think the only thing left is the timer
    have not got full model info so cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} need the pnc number to get it down to one model as there are 8 machines from 2 different factories with the above model no
    Grinner
    Dave, the Prod No. is 91609230200. Type P541212.
    I’ve just looked on the spares site, but it doesnt look like UkWhiteGoods sells them, so I’ll have to go elsewhere. Thanks
    #475133
    timer part no is 1251106215
    but you really need to check before changing things as it starts getting expensive
    also while i am thinking, when you tested it did you turn the timer far enough as the last 10 mins or so do not have heat so you have to set it for at least 30 min
