After months of making occasional grinding type noises on our Zanussi TD 524 I think I’ve found the problem. The front felt bearing has frayed and must have been getting stuck.
The part seems readily available – but would it be easy to fit? Is it just a case of pushing it into the gap where the old one came out? Or is there more to it?
Would prefer not to spend £300+ on a new machine if I can help it!! 🙂
Look forward to reading your replies, thanks for looking at the post.
Not that easy really, theres a lot of stripping down to be done, power off of course.
Top off then both sides & back off.
Lift out drum, fit felt.
Rebuild & hopefully no screws left over.
