Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Zanussi TDE4234W won’t start 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} the time
- This topic has 6 replies, 3 voices, and was last updated 5 years, 7 months ago by
effingpot.
September 9, 2020 at 12:13 pm #98317
effingpot
ParticipantHi,
My old Zanussi TDE 4234W works fine apart from the start button.Sometimes it works perfectly, other times not at all. We randomly open/close the door, turn the machine off/on and keep trying until it starts. You never have to push hard, just gently touch it so it seems like the on button itself is ok?
It’s like something is disabling it and I’m wondering if there is a door closed sensor or something similar that might be dodgy and telling the on button not to work?
Any ideas welcome as I don’t want to replace the whole machine for what is probably something simple.
MikeSeptember 9, 2020 at 5:32 pm #471815electrofix
Moderatorthere is a door switch so thats possible
September 9, 2020 at 5:46 pm #471816effingpot
Participantelectrofix wrote:there is a door switch so thats possible
Actually I played around a bit and without touching the door, turned the machine off and on, then gently pressed start a few times, then repeated until it started. So I think that may rule out any switch in the door latch 🙁 Bit stumped frankly!
September 9, 2020 at 5:55 pm #471817electrofix
Moderatorwhen you press start you are actually pressing a very small switch on the board. they can get dirty and only work sometimes, they can have bad solder joints that cause the same
September 9, 2020 at 6:08 pm #471818effingpot
Participantelectrofix wrote:when you press start you are actually pressing a very small switch on the board. they can get dirty and only work sometimes, they can have bad solder joints that cause the same
Thanks Dave, what would do with it?
Cheers
MikeSeptember 9, 2020 at 10:42 pm #471819electrofix
Moderatorwell i take the board out, look at the solder joint with a magnifying glass and use a multi meter to see if they work
October 6, 2020 at 4:29 pm #471820o_ptic
Participantive repaired my candy ages ago with exactly the same symptoms; my other symptom was that the machine would sometimes end the cycle short leaving the clothes damp. From memory it was the heater relay on the PCB which I replaced it and its still going strong.
