Can anyone explain how I gain access to replace the Front Drum Felt Gasket on my Zanussi TDS382W Tumble Dryer? The original part has snapped and ended up in the drum.
Re: Zanussi TDS382W Front Drum Felt Gasket Replacement
Thanks for the advice Martin.
Can you advise if the failure of the felt gasket is likley to mean that there may be a problem brewing else where, e.g drum bearings on the way out, or do the felt gaskets just wear out over time?
