Zanussi TDS383W Tumble Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi TDS383W Tumble Dryer
  • #12051
    Am finding that clothes are getting caught in the small gap between the rotating drum and static housing. Can see no obvious faults with the machine (sharp edges, bits of seal sticking out etc) and am wondering if this fault has occured before and, if so, what the fix is.
    Have contacted Zanussi to see if they can advise on this question and if there have been any upgraded parts/modifications. However, they say they can’t tell me due to product liability laws if I try to repair the machine and injure myself (fair enough in this crazy day and age). Zanussi put me in touch with the ServiceForce organisation, who won’t discuss the problem with me as they will only do site visits at £££+vat!! Whilst I understand they aren’t a charity, this does seem rather unhelpful
    Thanks in advance for any advice.
    #147669
    Re: Zanussi TDS383W Tumble Dryer
    Usually the rear bearing wears (Part No 1250134119)and the front drum support felt (1250028055) also. Needs a bit of expert TLC to fit these but a simple enough and cheap job for a local independent to sort for you. Try our Repairs@ to see if there’s one in your area?
    If you want a crack at it yourself, good luck and you can order the spares (giving the above part no’s) to spares@ukwhitegoods.co.uk
    #147670
    Martin,
    Many thanks for a prompt and helpful reply (more use than severla weeks of Zanussi and ServiceForce!)
    Regards
    John
    #147671
    Problem exactly as diagnosed by Martin, repairs speedily effected by ace appliances of Preston and machine back in service.
    Just got to write letter to Zanussi asking why they seem incapable of this level of help…
    #147672
    John wrote:Just got to write letter to Zanussi asking why they seem incapable of this level of help…
    If it helps get it off your chest John then fine. But better still, if you just reflect on the eventual outcome and instead tell all your friends about UK Whitegoods, I and my many colleagues here will be very pleased the story had a happy ending. 😀
    #147673
    Martin – noted and I shall certainly do so. Might also find Zanussi start to use the wb site – I shall certainly be telling them about it
    Regards
    #147674
    I’m 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain there’s a modification kit for this very problem – Martin or Dave, check in documents on TDS (Mine’s not working at the moment 🙄 ) for this model.
    Dave_Conway
    Yep, there are several bulletins regarding the front felt and bearings. It goes on the PNC (product code) and serial number as there have been a few versions of this model.
    Mainly new part numbers and advising engineers how to fit them corrrectly 😉
    #147676
    Penguin45 wrote:I’m 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain there’s a modification kit for this very problem
    Quite correct! The Mod Kit (Part No 50272165007) includes the replacement felt and 2 plastic ‘bearings’. Demand must be very low though as no-one stocks this part? (special order status 🙁 )
