Zanussi TDS483EW Condenser dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi TDS483EW Condenser dryer
  • #19785
    rocker
    Customer rang, tells me that this dryer is tearing and catching clothes,
    havent called yet, wondered if anyone has seen this before.
    Cheers John.
    #184498
    cab
    Re: Zanussi TDS483EW Condenser dryer
    hi these machines the drum runs on a felt ring only on the front this wears causing a gap which results in a gap appearing at the bottom, either tearing clothes or bepsting marks on them, a modification made to run drun on plastic bearing pads. kit part no. 50272165007
    #184499
    rocker
    Cab, thanks for your advice, will order and fit .
    Cheers John.
    #184500
    cab wrote:hi these machines the drum runs on a felt ring only on the front this wears causing a gap which results in a gap appearing at the bottom, either tearing clothes or bepsting marks on them, a modification made to run drun on plastic bearing pads.
    Now where have I heard that before, 😉 Hotpoint TDL anyone. 😥
    #184501
    Be fair Jim – Zanussi did it first. Inevitable that Hotpoint would follow, lemming like, of course.
