zanussi timer fault?
  • #43716
    abbots
    hi,
    FLS1397W
    customer says that machine fills with water and the drum does a few revolutions ,then the timer know starts clicking round and doesn’t stop.
    any ideas, maybe programmer faulty?
    cheers.
    john
    #278278
    abbots
    Re: zanussi timer fault?
    any one got a wiring diagram for this machine?
    i really dont want to order a timer for it if it isn’t the fault.
    cheers.
    john
    #278279
    roly16
    Have you checked the usual things like insulation resistance, heater continuity, pumping out ok , inlet valves, motor brushes?
    #278280
    abbots
    check brushes,element etc, nothing obvious.
    john
    #278281
    suedehead1
    have you checked the taco coil and magnet.
    #278282
    SL
    Replace the timer, this unit is driven by the motor pcb and the wiper contacts on the front of the timer wear, so the coding gets corrupted.
    The timer is looking for what “Service Force” call point zero which is a reference point on the cam pack.
    #278283
    abbots
    cheers guys.
    john
    #278284
    martinatmull
    As a service force engineer, i have been to two of these faults in recent months and it has been the tacho coil O/C. On one occasion it had fell off the motor, just put it back and away it went.
    M :o)
    #278285
    abbots
    cheers for that
    john
