Zanussi TLE 1116w
  • #43921
    PGS
    Hi called to above toploader today, fault was when prog selected it would tumle for a few secs then prog and option buttons would extinguish and end neon flashes. Indicating drum senser. In diagnostics I get 6 flashes and 10 flashes which I think equates to a fault code of E6A or EA6, can anyone shine any light on this or am i barking up a wrongin. Cheers Paul.
    #279077
    Re: Zanussi TLE 1116w
    there is a mod on this when you get an ea6 code after 30 secs
    problem is with reed switch on the pulley
    have you got this info? if not give me your email
    and product code if you have it will send you info
    PGS
    Cheers Dave the appliance stops working after just a few seconds as if it hasnt sensed the pully senser
    #279079
    mod shows packing the switch unit with washers to get it closer to the magnet but you have to grind injection tabs on back of pulley there are pictures no the bullitin
    need an email to send it to you
    PGS
    Dave Ive sent you a PM cheers.
    #279081
    PGS
    Ive cancelled the fault code on this machine and ran it 4 times over the weekend and fault has not re-ocurred. Could this fault on pulley senser be a 1 off or should I replace senser with mod kit. Any tips appreciated.
