zanussi tub change
  • #48040
    dpr1974
    Hi, customers zanussi (zwf1221w) wm needs new bearings, however it’s a sealed drum but all tub parts are available separately so i assume that this model changed tub type whilst in production. anyhow my question is this, would a tub from a zanussi fl1081 fit into the zwf1221w? this customer has had a bad year and if i can fit a tub from stock into her machine i can save her a bit of money. i would assume that all the pipe holes are the same, i’m just not sure about the diameter of the two door boot.
    David.
    #295367
    Re: zanussi tub change
    I think the older machine will have had a smaller drum and smaller door seal aperture. You really need a much newer donor machine.
    #295368
    dpr1974
    Thanks, i thought so but it was worth a shot.
    david
