Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Zanussi tumble drier needs help to turn.
- This topic has 13 replies, 2 voices, and was last updated 6 years, 1 month ago by
inveryes.
February 15, 2020 at 12:24 pm #97200
inveryes
ParticipantHi
My Zanussi ZDC 47200W doesn’t always start to rotate by itself. I need to load everything to the right hand side so that it has enough momentum to start rotating by itself. I can turn the drum by hand and once it does get going it’s fine. I’ve taken the top off and the belt appears fine, tight and in good condition.
Ive tried to follow a couple of online videos showing how to remove the back but even with all screws removed around the perimeter, the metal heater cover won’t come off. I’ve run a knife round the edge in case the rubber seal is sticking it, but it still won’t budge.
There is a small plastic fitting in the centre of the back which has an accumulation of very fine black powder in it. Any clue there?
Any advice on either of these issues would be appreciated.
Thank you.
February 15, 2020 at 1:44 pm #466518iadom
ModeratorSounds like a failed motor capacitor, usually accessed from side panel not back.
February 15, 2020 at 5:14 pm #466519iadom
ModeratorWould also need the PNC or product number to identify parts etc.
February 15, 2020 at 8:07 pm #466520inveryes
Participantiadom wrote:Sounds like a failed motor capacitor, usually accessed from side panel not back.
Thanks for that. It hums quietly when it’s trying to start turning. Serial Number is 13835750.
February 15, 2020 at 8:14 pm #466521iadom
ModeratorProduct or PNC number will begin with 916******.
Some of these later Zanussi dryers have 3 phase motors not old style capacitor run motors so correct identification is essential.
February 15, 2020 at 8:56 pm #466522iadom
ModeratorDone a little more digging, this machine does have a capacitor start motor, located behind the right hand ( from front ) side panel, screws down the back and one sneaky one up at the top/front. It’s a bog standard 8uf capacitor available in the forum shop here. https://shop.ukwhitegoods.co.uk/washing-machine-tumble-dryer-dishwasher-8uf-capacitor
February 15, 2020 at 9:57 pm #466523inveryes
Participantiadom wrote:Done a little more digging, this machine does have a capacitor start motor, located behind the right hand ( from front ) side panel, screws down the back and one sneaky one up at the top/front. It’s a bog standard 8uf capacitor available in the forum shop here. https://shop.ukwhitegoods.co.uk/washing-machine-tumble-dryer-dishwasher-8uf-capacitor
Have found the Product No. 916 094 547 00
Does that confirm the capacitor is what I need?
February 15, 2020 at 10:05 pm #466524iadom
ModeratorYes, at that price well worth a punt.:cool:
February 16, 2020 at 7:29 am #466525inveryes
Participantiadom wrote:Yes, at that price well worth a punt.:cool:
Thanks very much for all your help! I’ll give it a go!
February 17, 2020 at 9:29 pm #466526inveryes
ParticipantI’ve ordered the capacitor but am seeing comments online that I might have to discharge the existing capacitor before removing it.
How would I do that?
February 17, 2020 at 9:40 pm #466527iadom
ModeratorTake no notice, that would only apply to a good capacitor on a machine that was still plugged in.
March 7, 2020 at 3:22 pm #466528inveryes
ParticipantHi folks. Just came back to say thanks again and I bought a new capacitor and fitted it and everything seems to be ok.
One reservation. The capacitor had a different end fixing to secure it to the plastic mount in the tumble drier so I attached the capacitor with cable ties instead. I don’t expect anyone to endorse that as good practice but does the capacitor body get hot in normal use?
March 7, 2020 at 3:40 pm #466529iadom
ModeratorCable tie was one of the methods I used.;)
March 7, 2020 at 11:06 pm #466530inveryes
Participantiadom wrote:Cable tie was one of the methods I used.;)
Brilliant! Was going to buy a new tumble drier but bought a new capacitor from U.K. white goods instead for £3.95.
Thanks again!
