Zanussi Tumble Drier TC7102W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Tumble Drier TC7102W
  • #27231
    DentedPorsche
    Hiyas,
    Wierdest call I’ve ever attended.
    Customer complaining that machine isn’t condensing properly and that there’s not enough water in the container, clothes are being dried properly.
    Garage has been turned into a room, walls plastered etc.
    Drier is drying just fine, no water running down the walls and nothing untoward found with the drier itself.
    Has anyone had anything like this with a condenser drier.
    I would have though that there would have been a lot of condensation around if any seals were gone and water on the floor if there was a blockage. None of this though.
    Any help would be greatfully received.
    Brian
    #213152
    clivejameson
    Re: Zanussi Tumble Drier TC7102W
    Maybe there isn’t as much water in the damp laundry to start with?….Have you been fixing the washing machine? 😆
    #213153
    DentedPorsche
    Already thought of that one 🙁
    The only change is the garage, machine has always been there but now it’s a proper room instead of bare walled.
    Brian
    #213154
    suedehead1
    i had the same problem with this machine before and never got to the bottom of the problem it dried perfectly well but no water went into the condenser and no steam came out the machine.
    and no water appeared on the floor.
    #213155
    tedd
    i had this problem with a creda condenser dryer.there was a small hole in the water container which slowly leaked out and seemed to evaporate.the dryer wored perfectly but no water in container.you could check on the floor of dryer after use,regards tedd.
    #213156
    clivejameson
    One can only assume that when the room was just a garage the machine was also drying some of the outside (humid) air?
