Home › Forums › Public Support Forums › Spare Parts Help › Zanussi Tumble Dryer TD160 – parts help
- This topic has 4 replies, 3 voices, and was last updated 9 years, 8 months ago by
Dhillon.
July 26, 2016 at 12:43 pm #88890
Dhillon
ParticipantHi All,
In the hope someone can help with my query. I am having trouble with the element on my Zanussi TD160 tumble dryer not heating. I have narrowed it down to the thermal cut out in the vent/duct and ordered a new part.I received the replacement part but it only has two terminals (like the thermostats near the heater element) whereas the original had three wires going to it (black, black and pink). I called the spares company and they said it was the right part (54 degree stat) and they could see a bulletin by the manufacturer saying the part had been updated. Unfortunately there was no further information available on retro fitting the new part in place of the old.
Any idea how i can fit the new part using the old wiring? The old part had three wires going to it, two black wires and one pink. The new part has only two terminals.
Here are some diagrams which may help explain:
July 26, 2016 at 2:39 pm #439686Martin
ParticipantRe: Zanussi Tumble Dryer TD160 – parts help
You might like to check the old stat as those 2 black leads may well be joined internally? That being the case then they both would need to be saddled together on the new stat with the pink on the other terminal.
All the wiring diagrams for this model show just 2 wires going to the stat anyway. 😕
Any further queries you may have then can I suggest you give use the full PNc number off the rating plate (e g 916????????)
July 26, 2016 at 3:36 pm #439687Dhillon
Hi Martin,
Here are the Pnc details:Dryer Model: Zanussi TD160 (TYPE P 510020 L)
Product No.: 916760009I will try to see if the two black wires are joined internally and get back to you.
Cheers
DhillonJuly 26, 2016 at 4:15 pm #439688Seamy
Diagram shows internal connection of 2&3 pins of t’stat .
July 26, 2016 at 4:36 pm #439689Dhillon
Hi Seamy,
Great will take it apart and have a look at pins 2 & 3. I am hoping they are the two black wires. Will let you know.Cheers
Dhillon -
