The dryer runs for about 2 minutes the goes into anti crease ( tumbles twice, stops for a couple of minutes then tumbles twice etc)
An E50 error appears. Did diagnosis check showed a E54 error (drum motor blocked alarm).
Did another diagnosis check and displayed a E32 error (conductimetric sensor frequency too low)
The customer said this was a intermittent fault over the last 2 months. Its slowing got worse.
Anyone had this problem?
Too much load into the drum
? Too low power supply voltage
? Drum/Motor mechanical abnormal frictions
? Drum Motor Capacitor (disconnected or broken)
? Drum Motor Failure
