wdj1667w select dryer timer, starts ok but no power to dryer motor,heater,or valve.drum tumbles & pump works as normal.
seems like board fault.any ideas!
I guess you mean a WJD1667W? ……and if any single component is open circuit (i.e Inlet Valve coil – very common) then the machine will misbehave. AND not necessarily come up with an error code either!
Make condemning the circuit board your last option 😉
