ZANUSSI W/D WDA1255W,NOT DRYING
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ZANUSSI W/D WDA1255W,NOT DRYING
  • #15445
    barryfast
    Hi ZANUSSI W/D WDA1255W, FAULT NOT DRYING TWO IN ONE DAY
    😮 BARRY FAST
    #163628
    blackandwhites
    Re: ZANUSSI W/D WDA1255W,NOT DRYING
    I usually find the condenser tube on these models are blocked (if badly blocked the entrance to the fan chamber can also be blocked)with lint,or sometimes the triple cold valve,may not be letting any water through.
    Its also easy to forget that a partially blocked filter can stop the pump from empying the water out sufficiently for the short time it is on.(it may empty ok on wash when its on continuously)
    Hope im not teaching my granny how to suck eggs.
    Steve
    #163629
    barryfast
    Hi THANKS FOR THAT I WILL LET YOU KNOW BARRYFAST
    #163630
    I had one the other day where the plastic trunking had come detached from the dryer chamber probably due to vibration caused by uneven floor.
    Mike.
    #163631
    barryfast
    up date the water valve at fault thank for all your help barryfast
