Zanussi w/d ZJD2191 prod 914601218/01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi w/d ZJD2191 prod 914601218/01
  • This topic has 3 replies, 2 voices, and was last updated 4 years ago by alro.
  • #100701
    alro
    Hi gents machine spin ok and completes programme and drain ok select any wash programme fills to 1st level fills to second level no drum action and machine start neon flashing to say its on pause any ideas did find dryer heater was 0.53 mg on meter motor brushes ok as it spins fine cheers alro
    #481808
    start neon on a lot of zanussi units is the fault code. have you counted flashes
    alro
    Dave it shows up E40 but and the door is locked, spin and drains program work ok it only flashes as it reaches end of second fill up on wash or rinse progrmme you can hear like a relay drop out on pcb cheers alan
    #481810
    you need to go into service mode to get the actual code
