Zanussi W/D ZKI225 914606007/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi W/D ZKI225 914606007/02
  • #88770
    dunston
    The machine console panel does not light. Will not start etc.
    We have checked 240 volts to machine OK.
    Looks like a PCB fault. We have had problems with dryer elements.But they check OK
    Has anyone had this fault?
    Customer did have it on tumble dry when it went off.
    #439320
    Re: Zanussi W/D ZKI225 914606007/02
    Two possibilities, either the door interlock connections have burnt out or the main power board has failed. But that’s not to overlook the fact it failed during the drying process and therefore the dryer PCB or that darned dryer heater has something to do with it? 😕
    #439321
    it does sound like a pcb fault
    disconnect all the wires to the from pcb apart from the mains.
    if it lights when you turn it on then it may be external
    if it does not light then the only fault you can cure on the pcb power supply. open the board and look for the chip and look for a blown low ohm resistor normally 50 to 100 ohms
    Seamy
    Low resistance on dryer heating element causes the p.c.b to go blank on these sometimes, disconnect cables off element & tape up safely and securely, test to see if it powers up ok with dryer elements out of circuit.
    #439323
    dunston
    PCB faulty. Thanks
