Zanussi w/d zwd12270w
  • #58424
    senseib
    No matter what programme you set it on this w/d cancels itself after about 20 mins – the pause button starts flashing.
    Anyone had this before?
    Brian.
    #334509
    Re: Zanussi w/d zwd12270w
    senseib wrote:Anyone had this before?
    Good lord yes, besides lots of posts on the subject. Open circuit triple valve, blocked condenser ducting, element earth leakage, NTC connection fault are all suspects.
    Have you entered ‘diagnostics’ to find an error code? Does an error code flash up on the display?
    #334510
    Drier element down to around 30Meg insulation is favourite. Disconnect it and tie up the wires out of the way. Save yourself some time; leave the customer to test it through a few washes. If it’s fine and they didn’t need the dryer anyway, you won’t have to go back. But in case they decide for a new element, note the watts reading on old one as they vary.
    Mike.
    #334511
    leavemetogetonwithit wrote:Disconnect it and tie up the wires out of the way.
    With the element disconnected it will flag up an E71, E20 or even an EH1 fault. 🙁
    Best to just megger it I reckon. 😉 🙂
    #334512
    Never seen that before and I’ve done a few. Is there something different with this model?
    Mike.
    #334513
    Yes, I disconnected the dryer element on one on Friday then watched it complete a whole wash with no problems. The tenant who rents the furnished flat never uses the dryer anyway.
