zanussi w/dryer ,914604030/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi w/dryer ,914604030/02
  • #100213
    adv
    hi fokes . the dreaded not taking softener away ..whats it more likely to be the triple valve or hopper top ? or both , as if have to replace both job starts to get a bit pricey for such a minor thing :rolleyes:
    #479737
    could be either or both but you can check the valve
    adv
    electrofix wrote:could be either or both but you can check the valve
    how do you check the valve ?resistance valvue ?
    #479739
    check resistance and you can check flow if you put it into test mode and activate each valve
    have emailed the diagnostics
