zanussi w/dryer zkg7125
  • #94826
    adv
    any one clued up on these machines . not taken softner , tried cleaning , holes at top of soap draw . im thinking either top part off soap dispenser or triple valve ? whats common cause on these:rolleyes:?
    #458489
    adv
    looks like it has a triple valve . hard to know what time in wash to check that? . dont want hang around for ages , when is it ment to take it .sure in final rinse at sometime ?
    #458490
    it will be as its filling up for the last rinse. it will either turn both coils on all the way up or turn the second coil on when its three quarters full. either way once its full its too late
    check the coils first and take it from there
    adv
    cheers:cool::cool:
    #458492
    adv
    this is doing my . nut. fitted new soap draw top nightmare job, and . still wont take softner. i watch a hole rinse programme and no water went into softner section . on second last rinse water went into pre rinse section and dryer fan started running . very weird.. all coils fine .on valve .s soap draw spotless. also how the hell does . this change water flow from main compartment to softner one. seem to use same valve .. baffled . help ?
    #458493
    both the valves have to be energised at the same time. if only one valve energises it wont work
    let me have an email will send you the fault guides which give you a way of testing all valve condition without going through a programme
    adv
    adv1appliancerepairs@gmail.com . what would be the cause of both valves not energising at same time ?ta
    #458495
    look at the previous diagrams I posted above. the 2 jets of water hit each other in the back of the draw to force the water to fill the conditioner container
    have sent you the info
    adv
    still confused mate . and why did dryer motor kick in on second last rinse ? although dryer heater didnt come .on . i am not great on diagrams tbh , do you think changing triple valve will fix this . ..////??/ cant think of any thing else ?
    #458497
    forget the dryer motor weird I agree but its normal dryer motor always runs on last rinse.
    as for changing valve have you checked the coils on the valves
    if you run the tests in the manual you can test each valve by turning the knob. that way you can see the flow each valve is giving or non. if its non and the coil is energised then yes changing valve will cure it
    adv
    i checked all coils seem fine ,water went into pre rinse section also on final rinse . which i found bizarre also .
    #458499
    adv
    new set of valves sorted this cheers dave 😎
