Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi w/m long pauses
- This topic has 9 replies, 5 voices, and was last updated 14 years, 7 months ago by
simtoms.
August 18, 2011 at 4:15 pm #64581
simtoms
ParticipantHave looked at a Zanussi ZWF1431S recently which keeps stopping for prolonged periods mid cycle, although no fault codes come up.
have removed PCB, cleaned and checked. Have run test procedure with no result.
Sound like main pcb fault?
SimonAugust 19, 2011 at 7:37 am #357464Martin
ParticipantRe: Zanussi w/m long pauses
Maybe it’s that old chestnut i.e. the heater?
Although last one I recall with similar symptoms ended up being the pump. :D:
August 19, 2011 at 9:29 am #357465simtoms
Thanks Martin.
It seems to heat fine and drain out. Would it throw a wobbly if components are not within normal parameters, even if they work ok?
SimonAugust 21, 2011 at 10:12 pm #357466leavemetogetonwithit
Simon😕 So it’s after the main wash that things get held up? Not plumbed to hot instead of cold or to a very low pressure supply?
Mike.August 22, 2011 at 8:42 am #357467simtoms
Cold supply and pressure all good Mike. It seems to eventually get through the cycle, but stops for long spells doing nothing although the lights and display are all active. 😕 😡
August 22, 2011 at 8:59 am #357468wilf
whats the total time taken start to finish?
wilf
August 22, 2011 at 3:28 pm #357469simtoms
can be over 5 hours 😯
August 23, 2011 at 7:03 am #357470Martin
Got to be the pump I reckon. 😉
August 23, 2011 at 7:54 am #357471Seamy
simtoms wrote: although no fault codes come
If it didn’t drain in time it should give E21 fault, if pump was going out on o/l it would give fault code E23 or E24 if theres was a problem with triac supplying pump.
E32 can also show up during draining if electronic pressure switch senses water level descrapancies .I agree its likely its sticking at drain stage but in theory it should throw up a fault. Motor could be going out on high temp’ either which should throw up an E52 error.
Check error codes again, are you sure you are not deleting error codes without reading them.
August 30, 2011 at 8:55 am #357472simtoms
Sorry for late response. Thanks Seamy, pretty sure I havent deleted any error codes. Think I’ll pop out AGAIN and have yet another dig.
