Zanussi washeer dryer Prod..91460603901
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi washeer dryer Prod..91460603901
  • #95647
    rocker
    I need to replace the drum plastic pulley wheel, I need to know the locking nut socket size. please..
    #460966
    don’t know what you need to know but its described as
    part no 132 22 95-42 / 7
    Screw pack,washer,pulley,M10x26mm+Ø9.2/Ø38mm
    murv
    Not had one of these machines in for a bearing job yet so I would have to guess the spanner size
    The specifications are M10 thread 26mm long and a 38mm washer with 9.2mm hole. The head diameter is not specified but If it follows the standard rules it should be 17mm.
    Many manufacturers use custom sizes just to make life more interesting.
    Murv…
    #460968
    to be honest from memory its probably a torx head countersunk and if it is they are a pig to get out as they use thread lock
    very likely a countersunk torx head bolt
    they use thread lock so can be a pig to remove
